anonymous
7060 points
Posted on - 08/11/2011
In recent days my internet explorer would close every time I clicked on a link or even while browsing. Â
I don't understand, but I noticed that before that happened I could not get on the internet at all.
Internet explorer wouldn't even open.
I am connected to a broadband network.
It closes by itself every three minutes or so.Â
Internet Explorer closes without any reason
Hi Rose Taylor,
Internet Explorer if it closes by itself, this actually means that the browser is corrupted. It may have lots of cookies, history and cached files stored; these affect your browser to slow down when browsing.
Here are the possible fixes;
1. Re-install the software by running the CD provided by your vendor of your machine.
2. Optimized your browser and or reset the browser and restore advance settings. Go to Tools, Internet Options, and delete the browsing History, then Advanced and restore the settings and reset back into factory default.
3. Go to C:>Drive * C: > Program Files > Internet Explorer > Custom Double click install.ins and change the settings.
Tools, Internet Options, Advanced Tab and uncheck 3rd Party settings. These are the steps to solved the issue. Chao!
