mozilla
Posted on - 07/28/2011
I've experienced this kind of problem recently and can't find a solution on how to fix this kind of error.
Internet Explorer error message is “Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.” When you view the error report, it references Mshtml.dll.
Internet Explorer Crashes-Error in Mshtml.dll
Mozilla, this error is usually very common with internet browsers and usually caused by a bug or a wrong coding in the browser's files. You simply need to follow these steps;
Start internet explorer
Go to Tools and click Internet options
On Advanced tab, click to select Disable script debugging check box in the browsing section
Click ok and restart windows as well as the browser
Disable all third party add-ons since they also cause the error.
Go to Start->Control panel->Internet options->Advanced tab
Uncheck Enable third party extensions
You scroll down a couple of lines to see it.
This should be able to solve your error. Thanks
This behavior might be happen because of the Windows XP beta version is old. to resolve this problem use this method.
First of all delete smart tags from your Internet explorer.
switch off or close all the open explorer windows.
now go to control panel and click on add or remove program tools.
here click on remove or delete smart tags which are supported by Microsoft and from there click change or remove
or you can use this method
turn on internet explorer
on the top there is a tools menu click that
there opens an advance tab click to choose remove smart tags now select ok and then restart your internet explorer
