Internet Explorer Encountered Connection Error
Morning friends,
It just happened yesterday that when my IE got crashed. I was checking my emails and that time my IE stopped browsing and gave the error that IE has encountered a problem and needs to be closed.
I closed IE and then restarted it and after some time it again gave me the same error.
Here is the screen shot of error:
Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.
So, what I did next is that I downloaded an update of IE from internet using chrome and run that update. When the update finished IE started and then shutdown suddenly.
After that whenever I open IE it asks me to choose an application to open IE with. I need Internet Explorer for some of my task so please if any of my fellows out there know a solution for this error as in the image for Internet Explorer then please let me know.
Because it is very essential for me to use IE.
Answered By 5 points N/A #121897
Hi Looner,
This error message occurs when the Pdm.dll file is out of date.
The solution requires you either to disable script debugging or to update the Pdm.dll file. If you must have the script debugging capability, you have to update the Pdm.dll file. To update your version of the Pdm.dll file, go to the "Download the updates to the Pdm.dll from the product update Web site" section. Otherwise, to avoid this error, disable script debugging in Internet Explorer. If you are running Windows XP, use Guided Help to disable script debugging. If you are running any other operating system, go to the "Manually disable script debugging" section.
Download Guided Help to automatically disable script debugging
This solution can only be used with Windows XP. If you are running another operating system, go to the "Manually disable script debugging" section to turn off script debugging in Internet Explorer. If you do not want to disable script debugging, go to the "Download the updates to the Pdm.dll from the product update Web site" section.
This solution can be used for all operating systems. If you do not want to disable script debugging, go to the "Download the updates to the Pdm.dll from the product update Web site" section.
To manually disable script debugging in Internet Explorer, follow these steps:
1. Start Internet Explorer.
2. On the Tools menu, click Internet Options.
3. On the Advanced tab, under the Browsing section, click to select the Disable script debugging (Internet Explorer) check box and the Disable script debugging (Other) check box if it is present.
4. Click OK, and then restart your computer.
If these steps resolved the error message, you are finished.  If these steps did not resolve the error message, go to the "Download the updates to the Pdm.dll from the product update Web site" section.
This solution can be used for all operating systems except Windows 98 and Windows Millennium Edition (Me). Use this solution if you must have the script debugging capability. To repair and use script debugging, you have to update the Pdm.dll file. To update the Pdm.dll file, install the appropriate upgrades that are described in this section.
Note: If you are running Windows 98 or Windows Millennium Edition (Me), the following upgrades do not install an updated version of the Pdm.dll file. The only resolution available to you is to upgrade your operating system.
If you are running Microsoft Office 2000, upgrade to Microsoft Office 2000 Service Release 1a (SR-1a). To download this upgrade, visit the following Microsoft Web site:
https://support.microsoft.com/en-us/help/302751
If you are running Microsoft Visual Studio 6.0, upgrade to Microsoft Visual Studio 6.0 Service Pack 5 (SP5) or a later version. To download this upgrade, visit the following Microsoft Web site, click the Service Packs link, and then click the service pack version that you want to download:
https://www.visualstudio.com/
If you are running the Microsoft Script Debugger in Windows 2000, Windows NT 4.0, Windows Server 2003 or Windows XP, upgrade to a newer version.
Note: Although the Script Debugger upgrade is available for these operating systems, it is no longer supported. You can still download and use this upgrade.
To download this upgrade or for more information, visit the following Microsoft Web site:
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/debugger-download-tools
If these updates resolve the error message, you are finished.  If you still receive the error message after you download and install these updates, go to the “Next Steps” section for information about how to contact Support.
Answered By 0 points N/A #121898
To resolve this, you should restore your Internet Explorer settings back to factory default settings.
Click start and go to Control Panel, make sure you are in the Classic View, then open Internet Options. Click the Advanced tab and click the Reset option.  You can also remove and clear the cache by clicking on the content tab and click the button that says Clear SSL State. Re-launch your browser, or you can even restart your computer to make sure changes are applied. This most of the time resolves it.
Answered By 590495 points N/A #309315
Since you are using Windows XP, try disabling Microsoft Internet Explorer. Click “Start,” “Control Panel,” and then “Add or Remove Programs.” On the left pane, click “Add/Remove Windows Components.” In the Windows Components Wizard, scroll down and look for “Internet Explorer.” Uncheck it then click “Next” and follow the instructions.
Disable Microsoft Internet Explorer
After this, repeat the same steps and check “Internet Explorer” to re-enable the browser and then click “Next.” See if this works. If this doesn’t work, update Microsoft Internet Explorer to the latest version supported by your operating system. First, download Windows XP Service Pack 3 and install it to update your operating system. This is the latest and last Service Pack update for Microsoft Windows XP.
Once Service Pack 3 is installed, click to restart the computer when you are prompted to complete the update. After booting, download Microsoft Internet Explorer 8 and install it. This is the highest version of the browser to support Microsoft Windows XP. Microsoft Internet Explorer 8 supports Windows XP Service Pack 3, Windows Vista, Windows Server 2003 Service Pack 2, and Windows Server 2008.
Microsoft Internet Explorer 8 requires Windows XP Service Pack 3 that’s why you need to update your operating system before installing the browser. See if this works.
