Internet Explorer Encountered a Problem while Surfing
Ever been surfing the web in Internet Explorer with multiple tabs or windows open when suddenly you’re face-to-face with the following error message?
Hello Jahan,
To resolve the error you are getting when using internet explorer, you will need to use one of the following methods:
Method 1
Get rid of the smart tags support for the IE
Method 2
You will need to disable smart tags in IE
Carl
If you have downloaded some executable file they are causing trouble. Open IE, click on Tools, Internet Options, and delete all the temporary Internet files Also click option of removing offline contents.
If you have recently installed updates and problem is caused after installation then you have to perform a quick system restore.
Download Adware, spybot or CCleaner or any of these programs and run to remove alerts and Malware to make sure removal of content disturbing IE.
Go to the Control Panel, then Internet Options and then advanced tab uncheck the “Enable third party browser extensions” check box. This will disable all add-ons might be causing trouble to IE.
Click on start line, select Run and type inCMD then type following lines pressing Enter after each one,
Disable smart tags by going into Internet Options from Control Panel, Advanced Options and Tools.
That’s actually normal and it also happens to me once in a while. Most of the time, it’s just a fluke or a glitch in the system. When you encounter this problem, just try launching it again and see what happens. If the error happens again, try updating Microsoft Internet Explorer to the latest version.
If the problem continues, try using other browsers like Mozilla Firefox, Google Chrome, Safari, or the Opera browser.
