Internet explorer error when it run
You told that you getting error in Internet Explorer, it frequently stops responding, but you did not told which version of internet Explorer you using.
Internet Explorer 9 is the latest version of internet Explorer. If you are using an old version of it then you may face errors.
In your problem, my solution is updating the Internet Explorer it is older one. Then make Internet Explorer as default browser.
Remove all incompatible software which conflicts with Internet Explorer. If Internet Download manager IDM is installed then uninstall it and then again install compatible version of it. I hope your problem will solved in this way.
My suggestion is that; use other browser like Mozilla Firefox, Google chrome, opera etc. All the browsers are free. Download one of the browser of course the latest version of it. Then install it and make it default. It will work much better than internet explorer. From the statistics & blog research I suggest you to use Mozilla Firefox browser.
Thank you.
You did not include in your inquiry the version of Microsoft Windows you are using to easily find a possible replacement for Microsoft Internet Explorer. If you are using your operating system is default version of Microsoft Internet Explorer then I see no reason for it to not work. When I say the default version, it is the Internet Explorer that comes pre-installed when you installed your operating system.
This version normally can’t be uninstalled because it is integrated with the system. If you are seeing a bunch of errors every time you open the browser, although it is normal since it is the Internet Explorer, the best way to deal with this is to install a new version to upgrade it. To find the best version for your operating system, visit Windows | Download and Shop | Internet Explorer. The page automatically detects your operating system and will display the version applicable for you.
Hey Guys, take my heartiest love. Both of your comments charmed me. But Monte Mayor, your written comment may be right but it looks hard to me but Sharath, in short how easily you have marked why this problem was appearing. You suspicion was right, as a default version I was using so I tried to uninstall it but I couldn’t. Now your valuable advice helped me to get the right way, that was from your provided link I have installed the best version of my operating system as well I have followed the other tips too which were you have mentioned in your comment. After that, I have been surprised that my problem has disappeared. Sharath you are providing a simple instruction in how to solve the Internet Explorer issue and that is why I can easily manage the latest version of IE and it would run smoothly. Well done Sharath!
