When I attempt to access a few web links with IE 6 it comes up with an error message “An error has occurred in Internet Explorer. Internet Explorer will now close. If you continue to experience problems, please restart your computer “
Platform: Windows XP Prof SP 2, IE Version: 6.0.2800.1106: Update: SP 1
The error still exists even after restarting the computer several times.
It happens with sporadic websites and does not stick to certain ones. I see that it happens with mostly the software download sites. I have restarted the machine several times and still get the same error message.
Any suggestions?
Internet Explorer error while accessing a few links
This error will happen if you have not installed Java runtime environment. Some sites included Java runtime environment so if you try to connect without install the JRE this error will occur.
You need to install JRE before visit these sites.
Please go to following link and install JRE.
http://www.oracle.com/technetwork/java/javase/downloads/index.html
Hope this will solve your problem.
Try to reset the Internet Explorer settings by following the steps below:
1. Close all the programs and IE.
2. For Windows XP:
Click Start> Run and then type inetcpl.cpl on the search box.
For Windows 7 and Windows Vista:
Click Start and then type inetcpl.cpl on the search box and then press the Enter key.
It will launch the Internet Options dialog box. Under the Advanced tab> Reset Internet Explorer Settings, click Reset and then hit the Reset again. Tick the Delete Personal Settings check box if you want to remove the entire settings.
3. When it is done on resetting, click the Close button under the Reset Internet Explorer Settings box.
4. Restart your Internet Explorer and see if it fix the issue.
