Does anyone have issues with opening Marketplace or while browsing with Internet Explorer on your Nokia Lumia 800 within New Zealand zone then you have to do some setting changes in the APN settings or we have an APN setting added
Note: This blog applies only in New Zealand.
Once you have version 1.6 or newer. Open Network Setup and configure the Vodafone
Internet access point.
1. Start, swipe to Apps
2. Network Setup W
3. Click the '+' button on the toolbar
4. Enter the details below [leave the rest blank}:
a. Connection name: VFNZlntemat
b. Make this my current APN: Checked
c. Access point name: www.vodal'one.nat.nz
d. MMS access point name: live.vodafone.com
e. Proxy address: 172.30.33.35
f. Proxy port: B060
g. MMSC address: nup:iipxt.vodaiona.net.nz:‘pxtsend
S. Click the ‘floppy disk’ [save] icon on the toolbar.
You should now be able to access the Internet.
Some error codes we will get:
C00cee3b
C101a006
Internet Explorer issue on Nokia Lumia 800 in New Zealand zone
This problem on your mobile browsing really is network dependent. This means that the problem you are having might only be experienced by users within your same network or by users who are also using the same network provider as you are and not by users using different networks on their Smartphone. But this is not always the case as what I have experienced before with an older Nokia phone. I suspect the problem is with your handset’s configuration and not from your network. The best way of learning the solution is to contact your network provider and relaying your problem to them.
This is what I did to solve my problem before. Even if they did explain in details the exact procedure on fixing the network problem, it still didn’t fix my problem and I still need to device my own way on fixing the problem by trying different combinations based on the steps they explained until I finally made it work. After calling your network provider they will explain in details the steps you should do in fixing the connection problem. If it doesn’t work on the first try, create your own sequence based on the steps they explained.
