Internet Explorer Problem Please help
Hi All,
  I recently installed Windows 8 Development preview beta version into my Hp Laptop. I am having a problem with the Internet explorer because it keeps on shutting down when I am using it. Please help me to fix this bug. Thanks in advance
Answered By 10 points N/A #101113
Hello there! Since it is just a Windows 8 beta version, it is kind of like a test if it works well or not. So when a bug like that happens, you have to report it to the manufacturer so they can fix it. But anyways, you can try fixing the issue with the following:
Go to the Start > Search Internet Options > Advanced tab. Choose the Reset option and then OK. See if this fixes the problem.
Do a system restore on your computer. Go back to the day when your internet explorer is working fine.
Good Luck!
