Internet Explorer Problems with this Web page
Dear,
I am trying to open filehippo.com. I type this link in the browser and press CTRL + ENTER then below error is displayed. In the below error this is written that if in the future this error appears then double click on the warning icon in the status bar but I can’t see here any icon. Please anyone tell me how can I get rid of this error.
Internet Explorer
Problems with this Web page might prevent it from being displayed properly or functioning properly. In the future, you can display this message by double-clicking the warning icon displayed in the status bar.
Always display this message when a page contains errors.
OK Show Details >>
Best Answer by BrownAnna
Answered By 5 points N/A #124813
Hi Nicolebryan!
You may try to download and install the latest version of your Internet Explorer browser which is IE 9 to your computer to prevent this error to happen again. Please check this link
If you would encounter an error again then, try to uninstall the old version of your Internet Explorer from the Control Panel Programs Uninstall a Program.
Then, look for your IE browser and Left-click it to highlight it then left – click on Uninstall/Change option.
Click the FINISH button to complete the process. Restart the computer and reinstall the IE9.
Answered By 5 points N/A #124815
Hello Nicole,
An advice for you is whenever type filehippo.com please do not press Ctrl+Enter this will make the address which is an invalid domain name. This might be your problem as you see the following error.
But if this error comes again then there are many solutions you can try step by step:
1. You must disable the script debugging; you can find it on tools > Advanced > display a notification about every script error. Uncheck this box
2. From another computer or a browser test the web page again.
3. Always remove all the temporary files.
4. Update your browser to the latest version.
Thanks
