I am using Windows XP OS and when I loaded a web page on Internet Explorer, I received the following error message. Can you tell me how to fix this issue?
Thanks in advance.
Internet Explorer Script Error
An error has occurred in the script on this page.
Line: 1
Char: 52
Error: Unterminated string constant
Code: 0
URL: https://ipm.autodesk.com/ipm/acd/2012/enu/index.html?redirected=1&d=22&country=us
Do you want to continue running scripts on this page?
Yes No
Internet Explorer Script Error on XP
Hello Arthur
Script error in internet explore is caused by a custom script in a website that can't be run properly, you can ignore the error message if it appears on one particular website. By the way you can disable the script error notification by following these steps
For Internet Explorer 7, Internet Explorer 8, or Internet Explorer 9.
On the Tools menu click Internet Options. On the Advanced tab, click to clear the Display a notification about every script error box, and then click OK.
Internet Explorer 6
On the Tools menu, click Internet Options.
On the Advanced tab, click to select the Disable script debugging box, then click OK .
