Henryjack
Posted on - 10/21/2011
Hi everyone!
Why am I always getting pop up on Internet Explorer security every time I open it? My Internet explorer is in "protected mode" and I tried to click don't allow but I'm still getting it. Same thing happened when I click "allow". Even if I check mark the “Do not show me warning for this program again", it always pops up when I open Internet Explorer.
What will I do to avoid this?
Thank you so much in advance.
Here is a screenshot to enlighten you on what I am talking about:
Internet Explorer Security
A website wants to open web content using this program on your computer
This program will open outside of Protected mode . Internet Explorer's Protected mode helps protect
your computer. If you do not trust this website, do not open this program.
Name: Yahoo! Toolbar Assistant
Publisher: Yahoo! Inc.
Details: …6)Yahoo!CompanionInstallscpn0ytbb.exe
Internet Explorer security pop up
It is added on to your browser, a yahoo toolbar installed in your Internet Explorer. If you want to remove this one, Follow these steps.
1. Open your Internet Explorer.
2. Then go to Tools and Manage Add-ons then a new window will appear.
3. On the left side of the window you can see Add-ons type.
4. Then click Toolbars and Extensions.
5. Then locate the tool bar and click that you think the cause of the error and then click Disable at the bottom of the window.
6. A message will prompt if you want to delete that Add-ons and then click disable.
7. Done.
This pop-up gives you warning weather to allow the requested access or not. I would suggest to let this on this setting to give you an awareness of what program is trying to get the access into your computer.
However, if you are getting annoyed by this, you can disable this feature and is always allowing programs to come-in all the time without you knowing that the program has auto-access and allowed all the time.
In this setting, it might cause you too much headache if the program has virus infections or anything alike.
You can manage this add-on and don't let this pop-up window appear all the time.
Go to your Internet Explorer and click Tools.
Go to Internet Options and click Programs.
Click on the Manage add-ons button in the right panel.
Choose Toolbars and Extensions.
On the right Panel, scroll down and highlight Yahoo Toolbar.
Click on the button to disable the access.
This will step won't keep the pop-up all the time.
It won't give you a warning and do the same on the other application if you wanted to.
Following steps surely help you:
1. Open Internet Explorer.
2. Press Alt+x, Tool pop will appear.
3. Click Manage add-ons button present in Tool popup.
4. Choose Toolbars and Extensions in Manage add-ons popup.
5. Now scroll down and search Yahoo Toolbar.
6. Click the button to disable.
7. After performing these steps you won't get any warning popup.
