Cayden
Posted on - 11/22/2011
Dear All,
On new hard drive I have installed new Windows 7. Also, I had to install other programs that I need.
After last installation I have restarted the computer.
When it started up I couldn't start up any of the software that are installed.
All I got is a big error message that something is not right. What I did wrong?
Thanks
Cayden
:: (26EE0668-A00A-44D7-9371-BEB064C98683):: (BB06C0E4-D293-4F75-8A90-CB05B6477E…
System call failed.
Internet Explorer System call fail
This is a common case,I have heard about it and seen it a lot of times. Its really sad that all your hard work did not work out. Anyway,I think the real problem is with your ms windows 7 installation cd. I highly doubt that the cd is pirated or incomplete. As so you know,there are many old programs which can not be run in the new ms windows 7 system,because it does not support them. I highly suggest you buy a new licensed copy of ms windows 7 installation cd and install it.
But unfortunately if the problem still persists,I will recommend you to go back to the good old ms windows XP system. I think that is the best operating system up till now.
Good luck.
