Internet Explorer Update
I am having an older version of Internet Explorer installed on my PC. It is not functioning since I have not updated it. Can anyone tell me how to update Internet Explorer?
Type ‘Internet Explorer’ in the Search Bar of Start Menu. Click on ‘Internet Explorer’ and click on it to open. Click on the gear icon on the top right corner of the Internet Explorer. A drop-down list will appear. Click on ‘About Internet Explorer.’ A new dialog box will appear. Check if the ‘Install new versions automatically’ has a tick or not. Click on it, a tick mark will be enabled, and click on ‘Close.’ Further on, the Internet Explorer update will be done automatically.
Notifications
