Internet Information server is not running.
Hello! Friends.
I have a issue with the Internet information server, I am developing websites PHP, MySQL and asp.net etc. I am using EasyPHP for MySQL and .php.Internet Information server for .asp webs.
There is no  issue with EasyPHP but my IIS is not working. No error message is there. Please let me know how to solve the issue?
Best Answer by Puckett Buckner
Answered By 75 points N/A #125982
Hi Noorasim,
It seems that you have not started your Internet Information Service utility. To start it, use the following procedure:
– Click start on your computer then run.
– Type services.msc in the run dialog box and press enter
– Go to standard to and choose internet connection service
– Enable that service
Like in my case the service is disabled so  I cannot use IIS.
So enable the service in your case too.
Hope this helps.
_____
Lee Hung.
Answered By 0 points N/A #125983
Hi Noorasim,
Here are some possible reasons
· IIS might not be serving pages from directory -> try including html page in the virtual directory to make sure it is serving pages.
· You might be missing some xml file somewhere -> Review http logs and the server event logs
If all fails, you might need to reinstall IIS.
Hope this helps.
