Internet Router doesn’t get connected
My router's internet light is not lightning. It is off. I have wire broadband connection. I thought limitation of my net is over. but now it is the beginning of the month. What it means?
What should I do?
What should I do?
You are using broadband connection. Broadband is available in two ways there are: wire connection and Wireless connection. Your connection has stopped working. It just because of your Limited offer is end. But still in the beginning of the month you are not getting the connection. It might be because of your server has lost your connection password. And the cause of your Router’s light of is because of your Router lost its configuration.
Use the CD of your Router to fix it. And most importantly contact with your provider.I think you have got your answer.
