Hi friends,
Is there any internet speed booster softwares to increase internet speed ?
My internet speed is slow, I am connecting internet on computer through broadband, but the bandwidth is too slow. I tried to clear all backdoor usages but no effect. How can I overcome this shortfall. Is there any software to increase the speed of the internet.
Please help,
Freddie C Slater
Internet speed booster softwares to increase speed
    There is no such magic software which will boost the internet speed. It completely depends upon the tariff plan you opted from your ISP. You can check whether the system is getting the required connection speed from the ISP provider. Intel speed check is the best tool to test the speed.
If your internet is slow, just follow these steps or contact your ISP customer care:
1. Clean all the cables from modem and router. Maintain good enough ventilation around all electrical parts to avoid overheating.
2. Avoid using multiple devices. Never connect smartphones or tablets to the system while browsing and downloading.
3. Clear the cache i.e. temporary files (C:Users<username>AppDataLocalTemp). This really improves system performance.
4. Reset your modem and router, which indeed works many times.
