Prakashraj
130 points
Posted on - 04/13/2011
Internet usage meter. does anyone know of a software that can show us the stats on our usage
I have BSNL and Airtel used in my home and office. I want a software free or small price that can record our usage and warn us when we exceed usage.
Is there any software out there or any trick to record this and take precautions before we exceed the limits.
Software to track my Internet Usage
I think there is no software but I think the connection that you are using at your home or office does have your account from where you can easily check that your current usage is and what space or usage required. Thanks.
Go to this website. https://www.yahoo.com/. Search here AIRTEL or BSNL website from where you got it webpage link open it and check you have account in this and then you can check your account usage easily. Thanks.
Hi Prakashraj,
I have seen a lot of ways to track your Internet usage.
I made a research of some possible software's in order to use to monitor the Internet usage.
I have attached links of sites that are having this kind of software below:
Hope it would help you a lot.
Thanks and more powers.
