alwyn white
20 points
Posted on - 04/07/2012
Hi friends,
Can anyone let me know how to use existing Microsoft back-end Protocols? What are the interoperability options to access Microsoft Network Services in the Sun Java Desktop System Environment?
Thanks
Interoperability Options to access Microsoft Network Services
Due to availability of different protocols for e.g., the web service protocol which can help in enabling the protocol client for configuring and controlling the crawling function of the search subsystem, the Microsoft back-end protocols are used for achieving different functionalities. The data can be read, written and stored by a protocol server with the help of access services data run-time protocol. Due to the presence of several protocols, the recommended and the best way to utilize them would be based on their functions from where one can initiate them at present.Â
In order to access social activity data along with providing and modifying data and metadata stored in the service, front end and back end protocols work hand in hand. Its in the programming environment that they are mostly used. Apart from the need to be accessible, the Microsoft network systems in the Java system have different capabilities like opening PDF documents, word documents or even outlook. In order to attain the best results and solutions, they need to work hand in hand in perfect coordination
I hope this solves the issue
Thanks
