“Invalid class typecast” application error on Spybot Beta
Hello experts.
I'm getting an error every time I run Spybot Beta.
It does a complete scan but when it gets to the end of the scan and is about to post the results, this message comes out:
Hello experts.
Hi
The error is showing that your software is not working properly you see in the image showing above has written that SCan.exe is not working properly so you exe file is not working properly.
Exe file means execution file which execute the program and that file is corrupted or not installed due to which the software unable to show the scan result and therefore showing this message so the only option you have to do is:
1. Try to install the software again and before installing the software again make it confirm that you are using the right copy of the software to install and I suggest you instead of installing the previous copy you already have installed try to get the new copy and which should be complete because the previous might have not that exe file so your software was unable to proper run so bring the new and fresh copy or download the latest version of the software and then install and then scan your system it will solve your problem.
