Hello Troubleshooter,
Android Studio installation was successful without any error. The problem triggered when I try to launch the application I ended up with an error message. After a search, I even updated the IDE but no result still I get the following error message. Please help me to resolve the error. Thank you.
Invalid Config Path
Config path “C:Program Files (x86)Androidandroid-studioconfig” is invalid.
If you have modified the ‘idea.config.path’ property please make sure it is correct, otherwise please re-install the IDE.
OK
points
Invalid Config Path Android Studio installation
This is such an error that is appearing because of permission. The folder directed was inside Windows directory (C drive) that Windows won’t let to access without administrator. Right-click on Android Studio and select “Run as administrator”.
Also try changing a line inside “C:Program Files (x86)Androidandroid-studiobinidea.properties”. Edit it with Notepad.
You’ll see like this:
# Uncomment this option if you want to customize path to IDE config folder. Make sure you're using forward slashes
#idea.config.path=${user.home}/.AndroidStudioPreview/config
# Uncomment this option if you want to customize path to IDE system folder. Make sure you're using forward slashes
#idea.system.path=${user.home}/.AndroidStudioPreview/system
….etc
Remove # in front of the line before last.
….etc
Now launch Android Studio. It should work fine.
