“Invalid Data” error during hardware installation
Hi, I got this error for the first time. I am trying to install MagicJack on a Windows 7 pc. It says "Invalid Data". I have been using MagicJack with my other PC which is Vista but MagicJack is compatible with Windows 7. Any ideas? Thanks….
Answered By 0 points N/A #126732
Hello clickmaster,
 Well the main thing problem on this is the 3rd party CD burning software that may conflict in your MagicJack. I have found a better solution for this as i have found that there is no wrong with MagicJack and you could simply check the registry just follow the instructions.
Here i list the following steps that you need to do to be able to fix this conflict in your software.
1 Click Start
2 Click Run
3 Type regedit
4 Hkey_Local_Machine or simply direct to this one
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
5 Delete the "UpperFilters" entry
6 Delete the "LowerFilters" entry
7 Exit regedit
8 Finally, Reboot
And your good to go =))
