chrisstate 1030 points N/APosted on - 06/28/2011
I have a lot of pictures from all my photo sessions I attended, and stored it all in my computer. I am afraid if ever my computer will crash and all this photo will be gone. So I decided to create a CD backup of all my files. I used CDBurnerXP. They told me that it runs so great, so I downloaded a copy of it and installed at my computer. After installing it, I wanted to try it. when I run the application, error message was displayed in my screen.
I pasted below the screen shot.
Invalid file in command string.
File Pro 3cdbxp.exe does not exist.
After I got the error message, I pointed the error to CDBurnerXP not with my computer.
Since my computer is running without a problem before I installed CDBurnerXP, please share some ideas.
Dear after reading all your post and seeing its technical aspects there are something that are related with your matter.
First of all as you mentioned in last that before installing the software your PC is working fine without any problems and ambiguities but when you installed that software, this sort of problem begins to occur, so dear I think your software has some file missing which he is unable to retrieve.
So I suggest to install the software again or also it gives the same error means your software is corrupted then you should install it from a different place, also apart from this XP CD burner other burning options are also available like the most famous NERO burn and many more you can use.
I hope by trying these instructions your matter will be solved and purified.
Whats up chrisstate, you are right the problem might be on the software. The problem might be on the files in the software, the software might have been corrupted. Some of the system files usually go missing when a software becomes corrupted or incorrectly coded.
You may also need to delete temporary files in the registry and ensure all the direct x drivers are installed. You may then uninstall the software and reinstall it. Restart the computer afterwards. Ensure the destination drive is not full or inaccessible and the system files to be there. This should be able to solve the problem. Thanks.
If you have Windows XP, I don’t think you will have a problem installing CDBurnerXP because it completely supports Windows XP. I think it’s just a minor problem with the installation. Try to uninstall and reinstall CDBurnerXP or better yet just download the latest version. Download the free version of Revo Uninstaller and install it.
CDBurnerXP 4
Once installed, start Revo Uninstaller then select your CDBurnerXP among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the latest CDBurnerXP and install it.
See if this works. The latest version at the moment supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 including Windows Server 2003, Windows Server 2008, and Windows Server 2012.
1....
