jicocute
Posted on - 02/07/2012
I have a retail version of Sims 3 Ambitions, but I did not able to patch it when I first have it.
And now I need to patch it but the download manager of EA is not working. I manually downloaded the patch, but I got an “Invalid Region” error.
When I modified my registry based on the solution I found online,
I got another error and posted it below.
How can I update Sims 3™ Ambitions?
What invalid file is the error referring to?
Please help.
The Sims™ 3 Ambitions
Update Error: Invalid file found
Invalid File Found Error on Updating Sims 3
You must have to see which Region is your game and is it a digital release or not.
According to this, see the below choices you have to solve the problem.
1st Choice
- open your EA download manager.
- Update it and it will be converted to Origin.
- Run your sims 3 and update. It is very simple.
2nd Choice
Manually Download Origin.
- After download is complete, install it and do the same steps as the above .
3rd Choice
- I am giving you a link. Just click on it and the update will start. Here is the link.
4th Choice
- There is a super Patchier for games that are in EP2. You can download it from here. remember that is for standalone EP2 games.
5th Choice
- If your game is a digital release you need this one.
There is also a complete guide for this on this link and this link.
