donald hall
Posted on - 09/16/2012
Hi! I have an Asus Transformer EEE Pad and I am trying to connect it to my TV via HDMI but it always say Invalid Format. It won’t work with my other TV as well. But it used to work on both TV before. I have tried several resolutions and picture settings to no luck. What can I do?
Invalid Format on connecting Asus Transformer EEE Pad to TV
Hello Donald,
You will need to try the sync on the Transformer in order to find the Asus sync application on your PC. You can download it from the following Asus Web Site: https://www.asus.com/us/ > Services > Support > Download. After that you will enter TF101 in the model search option and go from there.
After you have installed on your PC, the sync application comes up with this screen on the PC:
http://www.softpedia.com/get/System/Back-Up-and-Recovery/ASUS-Sync.shtml
Carl
