Invalid mount option when attempting to mount the volume inScope
I want to transfer some files from my laptop with Linux to my PC with Windows 7 using LAN. This error appears and says that cannot mount volume. I don’t know what it means and I can’t copy the files using USB because is a large volume data. Any advice ? How can I make LAN connection between this two ?
Thanks !
Cannot mount volume.
Invalid mount option when attempting to mount the volume ‘inScope’.
OK
