Invalid Plugin detected. Adobe Reader will quit
             Hi people! I having problem with my Adobe Reader Installed to my computer. Last few days it works well, but when I open it recently error occurred every time I scroll down the Opened PDF file. I re-installed the software but still not working, I also update to a newer version but error still there. What happened to my computer? I installed adobe reader to other computer and it works well, is it a virus to my computer? Thanks.
Adobe Reader
Invalid plugin detected. Adobe Reader will quit.
Best Answer by Zorian Crust
Answered By 80 points N/A #111637
Hello Robert,
You can do the following step by step procedure to solve your problem.
  •  Reinstall the Adobe Reader with the same version or latest version
  •  Update Adobe Reader and Acrobat
  •  Install the same Adobe Reader Version 9.0 or latest version
  •  Install Other old Adobe Reader Version. It will work without a problem
  • Spot Adobe Reader plugin file
I already tried that solution and worked for me when I have encountered that kind of error. I hope it will work for you too. Have a great day and good luck. Message me if it will work. I'll be glad to know what happened.
-Zorian
Answered By 5 points N/A #111639
First thing you just simply download the error repair tools and then simply install that to your PC and then you just simply click the start from the software you downloaded and then try to repair the found errors to your software and then just simply download new software and then make sure that you properly downloaded correctly to avoid anything error or maybe problem before you install the software and then try to scan the your system if there an infected files or maybe an application from viruses and spyware in your computer just simply check on that if it’s possible.
Ben
