While playing a game I got the following error message that says
Invalid pointer or handle in native_steam_run_callbacks
It happens whenever I press the play button.
Please give me a solution. ASAP.
Hello…,
You’re using Microsoft Windows 7 as your operating system
Go to the location of the game and right click on the icon which starts the program.
Click properties,
This window will appear.
Go to the “Compatibility” tab it will be like this,
There is a “Check box” which is marked by a red circle in the window says “Run this program as an administrator”
Click it and mark it.
Click “Apply”, then “OK” to confirm the changes.
You’ll be able to run the game now.
