Invalid registration key error when installing Rank Tracker
Hi Gurus,
I had a working Rank Tracker in one of the PCs in the office to track our website.  However, while I was reinstalling it to another newly formatted PC, I encountered this registration problem.  I tried doing the same thing but the problem didn’t go away.  I knew the key we have is valid.  Can someone please help me to solve the problem?  Appreciate your help.
Sorry, this registration key is not valid. Please make sure that you enter all data correctly.
Or if you just changed your license type, please enter your new registration key.
Best Answer by Fraserr thor
Answered By 0 points N/A #155188
Hi Patrick,
thank you for using Rank Tracker! (I'm replying as Link-Assistant.Com's employee)
Judging from the screenshot you provide, something should have gone wrong when you entered the registration key.
Please contact our support at https://www.link-assistant.com/support/ – they'll check out your registration information and handle the issue.
Answered By 0 points N/A #155189
Rank Tracker is software with which one can check his site’s rank easily. There are two services: free trial and paid service. It needs to insert validation/serial/registration key to get a licensed version. After one has bought a licensed version, he has to insert the validation/serial/registration key to register his software copy. In your attached picture, it is saying that the registration key you inserted was not valid. So the trouble occurred. Insert a right registration key and the version will be registered for you and you will be able to enjoy the full service of “Rank Tracker” software.
Answered By 590495 points N/A #315966
If you have Rank Tracker installed on one of your computers but the registration key is not accepted when you installed the program on another computer and you know the registration key is valid, check if the registration key supports multiple machines. Most of the time, a registration key can only be used on one computer.
If you need to install the program on another machine, you need to purchase a separate registration key or a new registration key or purchase a registration key valid for a number of computers. To fix the problem, first, check if the registration key is valid for multiple computers. You can contact customer support for assistance.
Now, if the registration key is valid only for one machine then you need to purchase a separate registration key for the other computer. Try also downloading the latest version. Download Rank Tracker 8.27.1.
