bang oki
Posted on - 06/15/2012
I got a problem when I try to load iam by content center ipt.
Here is a snapshot of my problem.
Error:
Inserimento di file riuscito
Impossible caricare I'assieme C:Archivio——–10000008318.iam a causa di problemi con I file derivati.
File \ t3VaultCentroContenutiit-ITSS-EN-ISO 7045 HEN ISO 7045 – M5 x 30H.ipt non trovato
File \ t3VaultCentroContenutiit-ITSS-EN-ISO 7045 HEN ISO 7045 – M5 x 45H.ipt non trovato
File \ t3VaultCentroContenutiit-ITSS-EN-ISO 7045 HEN ISO 7045 – M5 x 8H.ipt non trovato
File \ t3VaultCentroContenutiit-ITUNI 5587UNI 5587 – M5 x 8H.ipt non trovato
OK
I did not get this error if I set inventor project file and copy the content center in local area. I get this error only if I set the Vault project and the content center is in network.
"The content center ipt is in a network and not in Vault".
I have no any idea of this case. Please give me a solution for this.
Thank you.
Inventor Publisher ‘Insert File Failed’ Error
The file that you are trying to load is either corrupted or damaged. Replacing it will solve the error but you need to know from where to replace it.
If you have the CD then insert it into the computer and run the repair tool so that it can repair automatically without your interaction.
If you do not have the CD then go to their website and download the latest update that they had released because this type of errors are tackled in it.
If you do not even have the internet then remove the program from the computer and reinstall each and everything related to the software again.
This will reset all things to normal
