Inventor Vault shows error while working on a project
Hello experts,
I am just working on a project using Inventor Vault but I get the following error message when I try to open any saved file using this software. Can you aware me about this problem? I just need your suggestion. Thanks in advance.
Inventor Vault
An unnamed file contained an unexpected object.
Answered By 5 points N/A #182707
This was included in the known issues of Inventor 2011. The known issue or the "bug" was mentioned here under Drawing Manager. Probably the issue will be fixed after you update your program since the report says it will be fixed.
This occurs when you're opening a drawing with customer templates from Windows 7 or Vista.
Meanwhiile, try to create a new drawing file and do not use any template then save it. This should open the file then.
