Inventory Management 0ic_c03 Part 1
I am new to SAP. The company I work for uses SAP every day. I do not know what is this inventory management 0ic_c03 part 1? Is it a software? Is it a document? Is it used regularly and something that I should learn it?
Answered By 0 points N/A #319435
The inventory management 0ic_c03 part 1 is a document. This document explains the importance and way of inventory management for each organization. It also contains a data flow diagram of inventory data from ECC to BI/BW System.
Inventory management is extremely important. It is considered to be the most challenging and expensive part of supply chain management. The inventory management 0ic_c03 part 1 is the first of three documents that describe the way SAP helps with supply chain management with the focus of this document being inventory management. You can read the complete document on the SAP website.
