IOS 7 new feature popup a window on trust and dont trust
Hi All,
As in this image this message pop's up everytime i plug my iPHONE 5 to the laptop. How can i switch off this as i connect always to trusted devices.
Trust This Computer?
Your settings and data will be accessible from this computer when connected
Trust | Don't Trust
Answered By 0 points N/A #198888
The problem occurs due to driver problems. Reinstall the USB drivers again. You can do this either by selecting Repair, which will automatically download all the drivers needed. Else go to Control Panel > Device manager. Look for the device that is connected, also check in portable devices. Update the drivers for the device with a right click. You can also manually select the driver:usbaapI64
