iPad audio background recorder for Windows 7 64 bit.
I have some audio clips in my iPad and want to record their background audio to PC which have windows 7 Ultimate 64 bit installed. Is it possible? If it is possible then tell me some iPad audio background recorder for windows 7. Also tell if there is an alternative way? Any kind of help would be appreciated.
Answered By 0 points N/A #148455
It is possible to record background audio from your iPad to computer. There are many applications for this that you can download from different website in the net. You can use QuickVoice recorder or Smart recorder that you can download from iTunes’ App Store. Using either of these application, you can also convert your background audio into what format you desired
