iPad css dropdown not working
I am using IPad and it is shows error : Dropdown menu not working. Please resolve my problem "iPad CSS dropdown not working" with complete solution.
Thanks!Â
Best Regards
Thanks!Â
Best Regards
Hi, Tracey David
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to get over come from Ipad css dropdown not working.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below:
https://stackoverflow.com/questions/9176639/drop-down-jquery-css-menu-not-responding-on-ipad-iphone
