I have this error when I try to download an app from Store on my iPad. I have this error only for programs and not for games or music. My Internet connection is working OK and this started to appear from 3-4 days ago. Can anyone help me please to fix this ? What is wrong with my iPad ?
Tanks !
Error
*** could not be download due to an error. (403)
OK
iPad error 403 could not be download due to an error.
If downloading an app from the Mac App Store always throws an error, this is probably because you are using an outdated version of iTunes. This problem should be fixed if you have the latest version installed on your computer. To download, visit iTunes 11.2 Download. Once downloaded, uninstall your existing iTunes then restart your computer.
Install iTunes 11.2 and then try downloading an app again. See if this works. For Microsoft Windows, it supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8. If you have a 64-bit operating system, download the 64-bit version from iTunes 11.2 x64. The x64 iTunes supports Windows Vista, Windows 7, and Windows 8.
Microsoft Windows XP is not supported on the 64-bit version.
