IPad keeps crashing with certain app
I have been using my iPad frequently and not made any changes other than updating apps.  However, when I access Pinterest, the iPad crashes.  I have had apps crash before, but when I try and use the latest Pinterest update, the entire iPad freezes.  Is it possible I have a virus?  I have the latest game update, and I have tried deleting the app and reinstalling.  Thank you.
Answered By 0 points N/A #191634
Hi, Anthony P Pettis first we should consider what model is your iPod one of the main reasons why your iPod freeze is low on memory. If you're low in memory your unit cannot cope up with your gaming. To protect your RAM from overheating, also you need to upgrade your OS because some application don't run any more in the old OS. Malware cannot be the reason for that.
Answered By 590495 points N/A #310496
If your Pinterest app is not working properly and you are using the latest version of the app, make sure your device’s operating system is supported. Try updating your iPad to the latest iOS. Once your device is updated and running on the latest firmware, delete your current Pinterest app then download the latest Pinterest on the Apple App Store.
The latest version at the moment requires iOS 9 and higher. It supports iPhone, iPad, and iPod touch. This is a free app rated 12+ for: infrequent/mild mature/suggestive themes and infrequent/mild sexual content and nudity. With the Pinterest app, you can discover everything from recipes and home ideas to style inspiration and make-up.
