IPhone 4 doesn’t work, help!!
What's happening on my iphone??
After I put down my iPhone it gives some problem to me. The phone is not getting on. I think it has broken. What will do? I will be thankful for your help to get out of this problem and fix my iphone asap..
Answered By 20 points N/A #117929
Hi Jun,
Are you getting an icon to plug it into iTunes or a totally blank screen when you turn it on? If its displaying the connect to iTunes message, try to plug it into iTunes and see if it will load.
Make sure that the battery is not dead and fully charge. Connect it to its iPhone charger or via USB to your computer.
You can also try to reset it by pressing the sleep/wake button and the home button at the same time. You need to keep on pressing the buttons until you see the Apple logo before you release it.
Aristono
