Shukla
40 points
Posted on - 08/03/2011
Hi All,
iPhone 4 Problems. What Users Complain about iPHONE4 issues?
Can anyone tell me all issues you have gone through with this phone. Just need to decide on before i purchase one.
regards
Shukla
IPhone 4 Problems. What Users Complain about iPHONE4
The reception issue is the most important and the basic issue of the I Phone 4 set. As the I phone 4 is famous for its amazing and attractive smart shape and appearance so it is very difficult to handle it and a lot of care is needed to handle this set. The other major problem with iPhone4 which i have personally experienced is that its antenna quickly loses its reception which is unbearable. Its glass screen is so sensible that it may be damaged or breaks due to a small mistake, so a lot of care is needed to prevent its sensible glass screen. The last one and the most important issue with the I Phone 4 is its low quality camera and its low quality results. If you want to purchase an I Phone 4 for its camera use then it is useless for you.
Hello, iPhone4 is now good for all who works in better online user.It is a smart phone Basically cell phone is probably favour man's skilled about how he/she want like only call and receive to others and only internet connection or A to Z.i like all the i phone.
Normally,you make sure that i phone based on what software and is it your types?default using is best now for i phone.through network connection it may be disturb you.don't worry.all software on i phone like chatting,videos,players,yahoo etc you install must be upgrade.it is less important to increase your data through mobile.hope you will not face any problem without any reasons.safely using is better to decrease problem.thanks
