I dropped my iPhone 4 when I was running late to school. When I checked it, it turned off itself.
When I opened it, the screen is all blank. But the backlight is okay so I think it was on.
I restart it and it was working fine then. But up to date, I'm still having moments of blank screens whenever I turn it on.
Aside from that, I did not noticed any other problems.
What can I do to fix this?
IPhone 4 Screen is Blank
Hello Dear,
I request you not to panic because it is not a serious problem. If your iPhone 3G, 3GS and iPhone 4, it can be solved or we can say fixed easily.
If your phone turn on a while, then resetting the phone may prove helpful
There is a Sleep/Wake button that u know. Also there is a Home button. You just need to press this button one by one simultaneously and also keep holding this button while pressing. At a moment, apple logo will appear on your blank screen. This logo in blank screen means your resetting job is finished.
Hope this will work
