IPhone 4s download abilities and applications
How can you expand the ability of an iPhone 4s in downloading musics, videos and other applications?
Best Answer by Tamoso Cumma
Answered By 0 points N/A #104349
For you to expand the ability of an iPhone 4s, you need to keep your applications updated. Installing and updating the applications will boost the performance of the iPhone 4s. In order for you to do this, you need to follow these simple steps:
  • Make sure the iPhone is fully charged and that your laptop is plugged in using the battery charger.
  • Just a pre-caution for installing the updates for the apps you do not want any of the gadgets to drain their batteries and will be a result of an unsuccessful software update and there is a possibility that you will have problems in using the phone due to the update did not finish uploading or downloading the program. If you are using a desktop then skip this step.
  • Tap the iTunes icon and wait for a few seconds if a window shows up asking you if you want to update iTunes then tap yes. Then you will have to restart iTunes once the update has finished.
  • Connect the iPhone to the computer using a USB connector and wait until it is recognized by the iTunes apps.
  • Then on your computer, click the iPhone icon.
  • Upon clicking on the icon wait if there will be a pop-up box that tells you that there is an update available to download, if not go to the larger iPhone icon and click the “update” option in the main window.
  • There will be a list of applications that are needed to update if there are available updates, just tap on “Next” and proceed with the installation.
If you do not have any iTunes installed follow these steps:
  • Go online to the Apple website which is https://www.apple.com/iphone/ and look for the iTunes download link and install it to your computer.
  • If you want to download more applications for your iPhone here is one of the websites to do so https://www.apple.com/iphone/ all categorized so you can easily find what you need! If your iPhone has no iTunes you can download it as well.
  • You can also download applications to enhance the way you listen to music or watch a video or movie these apps are: Sound Hound, Guitar Toolkit, Songify, Beatwave, Spotify and more. You can get more apps most of them are free at the Apple website.
Answered By 590495 points N/A #104350
I think with the stuff you are asking it will surely generate you big data charges since the service you want will use most of the network. If you frequently want to do these like watching streaming videos over your Smartphone, downloading different kinds of music and applications, before you begin you need to make sure that your phone is fully charged to avoid any interruption while you were downloading different files over the network.
And since you want to do all of these with your phone, check first if your present signal is strong or weak. Because a mobile phone relies on wireless network, there are times that the signal you receive becomes extremely weak and this is not the good time to download something over the network. The internet speed on the phone relies on its signal strength. You will get a good speed if not the maximum if you have a strong signal and a very bad speed when it is weak. And I’m sure you already noticed on the screen of the phone, the signal of the network on the side is not steady and sometimes fluctuating. You need to check this before attempting any download.
