I have been using my iPhone 5 for awhile now for awhile. I noticed after the last update the battery on my phone keeps getting worse. I can not seem to keep a charge now at all. Is there a problem with the latest update. Or can you replace the battery in a iPhone?
IPhone 5 Battery Drains After Updates?
Hi, Joseph K Carpenter knows your battery is fine. There's nothing wrong with it. But you have to do some assessment of your unit. One Basic assessment is to check some application that is running in your background FB application eats a lot of power also the GPS and the mobile data. YOU have to always clear your Memory data in that way you can be sure that your power is utilized properly. When you're not using your wife turn it off. also much better solution if to factory reset your iPhone that way you can be sure that any hidden malware will be eliminated also if that the case.
