IPhone 5 Coming on August 7
Is it true that iPhone 5 is getting released on August 7th. When it will be available to other countries if it gets released on August 7th?
Dear Christopher B. Pyles, I have read your query.
Yes you are right; according to a report on Know Your Mobile launch date for the new iPhone 5 will be August the 7th. It will be a new designed device with a new casing design compared to iPhone 4s. It will be equipped with a Quad Core processor, probably a low power 32nm version processor, which will be designed by Apple and manufacturer will Samsung. S5L8950X CPU will be used probably. RAM will be 1 GB. It may have a smaller dock connector compared to iPhone 4s. It is also expected that new iPhone 5 will support 4G. It is rumored that Steve Jobs was working himself on a new and completely redesigned iPhone before his death, so it could be concluded that it was the same model, as 4s was same as 4 in design, there were a little difference. If it is going to be launched in August, then it can be figured out that it will come to other countries in September or October.
Hope it helped.
The Apple iPhone 5 was announced and released on September 2012. It supports 2G, 3G, and 4G networks and uses a nano-SIM card. It measures 123.8 x 58.6 x 7.6 millimeters and weighs 112 grams. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It is protected by Corning Gorilla Glass with oleophobic coating and supports multi-touch.
It runs on iOS 6 upgradable to iOS 7.1.2 and iOS 8.2 powered by Apple A6 chipset, Dual Core 1.3 GHz Swift [ARM v7-based] processor, and PowerVR SGX 543MP3 [triple-core graphics] GPU. Unfortunately, it doesn’t support microSD. It runs on 1 GB DDR2 RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 8 megapixels at 3264 x 2448 pixels with LED flash and autofocus.
It features HDR photo, panorama, face detection, geo-tagging, touch focus, simultaneous HD video and image recording, 1.4 µm pixel size, and 1/3.2'' sensor size. It can record video in 1080p at 30 fps. The secondary camera supports 1.2 megapixels and can record video in 720p at 30 fps with FaceTime over Wi-Fi or Cellular and face detection.
It supports Bluetooth 4.0 with A2DP and LE, GPS with A-GPS and GLONASS, microUSB 2.0 reversible connector, and Wi-Fi 802.11 a/b/g/n with dual-band and hotspot. It includes compass, accelerometer, gyro, and proximity sensors. The built-in browser supports HTML5. It doesn’t support Java. It runs on non-removable [5.45 Wh] Li-Po 1440 mAh battery with standby time up to 225 hours both on 2G and 3G and talk time up to 8 hours both on 2G and 3G.
