I have just lost access to my Iphone 5C phone due to a forgotten passcode. I have very important information that I really need to access right now but I am unable to. Is it possible to recover lost passcode from Iphone 5c? How do I go about it without formatting the whole system settings? I would greatly appreciate your hepl with this?
Iphone 5C Passcode Lost. Please Help
You just can’t get your password without formatting, But you can save all of your files by backing up your iPhone, If your PC is the one you always use to sync your iPhone, You should sync the iPhone to this PC, And select sync apps, Then restore it from the back up you just did, The backup saves your app states, So all of your information should be safe, This is a risk, But you have no other option.
