IPhone 5,no external memory slot
Hi, recently I bought the apple iPhone 5, there is no external memory only there is internal memory. I need large memory storage Is there any solution for use the internal memory as external?
Hi Robert,
I think I had found a solution to your problem. All you need is an expansion device for you IPhone 5.
There are expansion device such as iExpander which will enhance several feature of your IPhone 5 such as Camera lighting, battery life and upgrade memory by using an external memory provided by the iExpander SD card slot.
I hope this will help you.
Roberts,
The logical solution would be to make use of the Icloud service offered by Apple. With I cloud you will be able to keep all your documents on a server. Your Iphone then connects and makes all these documents readily available to you. Another great plus point is that you can access these documents/files from any pc with an internet connection.
With this option there is no extra devices to carry around, and nothing that alters the appearance or size of you Iphone.
Hope this helps
If you’re talking about iPhone, I don’t think there has been an iPhone with microSD support. If you need a much bigger storage, you can use a card reader with a microSD card to allow you to expand your phone storage. The Apple iPhone 5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies.
It was unveiled to the public and released on September 2012 measuring 123.8 x 58.6 x 7.6 millimeters and weighing 112 grams. It uses nano-SIM card and has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass with oleophobic coating.
It ships with iOS 6 upgradable to iOS 10.2 powered by Apple A6 chipset, 1.3 GHz Dual-Core Swift (ARM 7-based) processor, and Triple-Core PowerVR SGX 543MP3 GPU. microSD is not supported. It runs on 1 GB DDR2 RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities.
The primary camera supports 8 megapixels with f/2.4, 33mm, 1/3.2″ sensor size, and 1.4 µm pixel size featuring LED flash, autofocus, face detection, panorama, HDR (photo), touch focus, and geo-tagging. It can record video in 1080p at 30 fps. The secondary camera supports 1.2 megapixels with f/2.4 and 35mm and can record video in 720p at 30 fps featuring FaceTime over Wi-Fi or Cellular and face detection.
It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support, Bluetooth 4.0 with A2DP and LE support, GPS with A-GPS and GLONASS support, and USB 2.0 reversible connector. It doesn’t have stereo FM radio. It has built-in accelerometer, proximity, compass, and gyro sensors. The preinstalled Safari web browser supports HTML5.
Java is not supported. It runs on non-removable 5.45 Wh Li-Po 1440 mAh battery with standby time up to 225 hours both on 2G and 3G. Talk time is up to 8 hours both on 2G and 3G. It is available in black/slate and white/silver colors.
