Alex Joshuaa 20 points N/APosted on - 09/23/2014
I am thinking of buying one of these phones, but I cannot seem to be able to choose which one is the best. I like both designs, so looks are not an issue. However, I would like to get my money’s worth.
Which of the two performs better? Which offers more uses and flexibility? And, last but not least, which will likely offer the highest resell price?
The Samsung Galaxy S5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on February 2014 and released on April 2014 measuring 142 x 72.5 x 8.1 millimeters and weighing 145 grams. It uses micro-SIM card and is IP67 certified (dust and water resistant up to 1 meter for 30 minutes).
It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 3 featuring TouchWiz UI. It runs on Android 4.4.2 KitKat upgradable to Android 6.0 Marshmallow powered by Qualcomm MSM8974AC Snapdragon 801 chipset, 2.5 GHz Quad-Core Krait 400 processor, and Adreno 330 GPU. It supports microSD expandable up to 256 GB.
It runs on 2 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 16 megapixels with LED flash, phase detection autofocus, f/2.2, and 31mm featuring geo-tagging, touch focus, face and smile detection, panorama, HDR, 1/2.6″ sensor size, and 1.12 µm pixel size and supports 2160p video recording at 30 fps, 1080p at 60 fps, and 720p at 120 fps with HDR and dual-video rec.
The secondary camera supports 2 megapixels with f/2.4 and 22mm and supports 1080p video recording at 30 fps with dual video call. It has 3.5-millimeter jack featuring 24-bit/192kHz audio and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.0 with A2DP, EDR, LE, and aptX support; GPS with A-GPS, GLONASS, and BDS support; NFC; infrared; and microUSB 3.0 with MHL 2.1 TV-out and USB Host support.
It doesn’t have FM radio. It has built-in front-mounted fingerprint, accelerometer, gyro, proximity, compass, barometer, gesture, and heart rate sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on removable Li-Ion 2800 mAh battery with standby time up to 390 hours and talk time up to 21 hours. It is available in electric blue, charcoal black, copper gold, and shimmery white colors.
1....
