IPhone app to play videos
Asked By 210 points N/A Posted on -
I have an IPhone 4 16 GB, that I am trying to put movies on. Without sacrificing that much space, what is the best file format & size that I can do that with, without sacrificing quality either?
And are you able to recommend, a lovely file converter for any type of file I have such as MKV.
Best Answer by Jack Fernandes
Answered By 0 points N/A #82609
Hey,
If you don’t want to compromise on the video quality, then there is no solution but to save it in a video format, mpeg4. This gives good quality videos but takes lots of space.
The best format to get good quality video, plus less space consumption is .RMVB format. This format will meet your expectations as you want less space occupied and better quality of the video.
The converters for the conversion are:
  • Xilisoft
  • Aves Converter
There are many other converters you can find on http://download.cnet.com/windows/
These are renowned converters for iPhone conversion.
Hope this will help you.
Answered By 0 points N/A #82610
You can use the MP Movie Player Controller Class, by just creating a class which you can initialize with the video's URL. This can play the video in full screen and directly returns back, to your application when done playing.
Another thing is, you can create a UIWEBView in a small size, only on your screen by loading it with YouTube embed code. It will result, likely to the image below:
It shows the play button on the screen. When you just tap the image, it will automatically open full screen and if video is done, it will return back to the normal small size.
