IPhone | Apple iPhone | iPhone Data
There is an application on Cydia where you can use iPhone 3G and 3GS to Bluetooth, your files to your mobile phone. The application is called IblueNova. You need to have a jailbroken device to install and run this application.
You can also try putting your files on your PC, then transferring it to your mobile. Normally if you want to transfer data from the iPhone, it doesn’t allow you. As technology is developed, solutions are available for this problem. Try iPhone to PC Transfer, it is a third party software that is used to transfer iPhone data. It is a great tool which provides you an option to easily backup your music, photos, videos, songs and much more.
You can transfer files or data on other mobiles from an iPhone, easily. You did not describe your iPhones' name, no, model etc. However, I guess you may be having a smart iPhone.
Smart iPhone has many functions for transferring files or data onto other mobiles from an iPhone. First option is Bluetooth. Now every iPhone has Bluetooth devices built in. If other phones which you want to transfer data have Bluetooth then pray with it and connect. Then transfer files or data on to another mobile from the iPhone.
Other option is infrared. It is not available for all iPhones. But many iPhones have this device too. If you have something like that then you can use it too.
