Is iPhone backup reader/viewer compatible with Windows?
Is iPhone backup reader/viewer compatible with windows? I’m looking for an option to have iPhone data back-up on my windows spare computer. I’m not sure if it’s PC compatible, I can only see one for MAC. Any idea?
Answered By 0 points N/A #151278
You can use iCloud or ITunes to back up your phone data. To back up them on your computer using iTunes, use the following steps. First, open iTunes and connect the device to your computer using the supplied USB cable and select it in iTunes under Devices on the left. It may be that some tabs are not displayed if no data is in your library. For example, the Podcasts tab is not displayed if no podcast is not in your library. To perform the synchronization, click Apply at the bottom right of the screen. You can also synchronize contacts, calendars, bookmarks and notes with other applications on your computer. So you keep all your information in sync across multiple computers and devices. The parameters of these elements are listed in the Info tab of your device in iTunes. Connect your device to the computer and select it. Then click the Info tab.
