IPhone Battery Management/Maintenance drains frequently
Please help me find solutions on my iPhones battery. It has a latest software, from Apple but it always gets drained, almost every hour.Â
Thanks in advance.
Thanks in advance.
I think, you need to lessen your usage of other applications; such as retrieving emails and sending emails through your phone.
You can save  power by just checking fewer email accounts.
Are you really sure, that you are using chargers that only fits for iPhones? Â Just use only the official Apple chargers.
Don't  overuse your battery, as it might be the cause for the battery to consistently experience draining out and wearing out prematurely.
Yes, all my accessories for my phone are original Apple accessories. Â I think one of the main cause is, sometimes I really forget to charge it, unless it is really drained out. Â
And I always use it for checking my email and FaceBook accounts.
Just follow the maintenance guidelines of your battery and keep unused applications, out of the phone. Â
If it is really not very important, don't check your Facebook account through your iPhone.
If you are still experiencing a problem on maintaining your battery life, I think you need to have an extra battery for your phone and be sure that it is original. Â
You need this especially, if you are out of your home and you don't have a place to charge your phone. Â This is a practical tip, you need to follow, have an extra original battery.
Great Idea expert Vinop. Â
I Â agree 100% , have an extra battery.
Thanks for all your tips and I really need to buy one battery, because I really need to check emails since I am working mostly outside the office and don't have a computer to use. Â
Thanks for the time 🙂
