IPhone Browser(software to view files on iPhone) not Running
Earlier iPhone Browser worked on my 32 bit System and it was an easy way to put songs browse contacts see app data on my iPhone. But now this software suddenly stopped working on my Laptop. After starting it says Not Responding. I don't know how to use iTunes. Please tell how to make that software work.
Answered By 590495 points N/A #145396
I guess you are using a different application other than iTunes to add files to your iPhone. The right application to use to add stuffs on your phone is iTunes and with it, you can easily synchronize or add songs to your phone. To download the latest version, visit iTunes 12.0.1 Download.
Problem is you did not mention the name of the file browser you used for your iPhone so we can better check if a new version is available. As an alternative to your file browser, try using iFunBox. You can use it to install apps and manage files on your device.
It is available for Microsoft Windows and Mac OS X. To download, visit iFunBox File Manager Download. Another file manager you can use on your iPhone is iExplorer. You can use it to transfer music to iTunes and also export iPhone text messages. It is also capable of mounting your iPhone or iPad to Mac OS X’s Finder or Microsoft Windows’ Windows Explorer.
iExplorer is available for Mac and Windows. To download, visit iExplorer File Manager Download. It now supports iPhone 6 and any iOS 8.1 devices.
